& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
i was wondering if you can draw a circle which would be tangent to two arcs and a line.i see it has circle tangent to 3 lines.
i accomplished it drawing the two arcs and line drew a arc and then used tangent constraints
just wondering if there was a command i dont know
Hi
This is done standardly - draw an approximate circle and give it 3 constraints.
Kacper Suchomski
One issue for the general case is that there are 4 possible solutions for the circle between two arcs and one line. In the image if you used the 2 blue circles and the blue line as your input, the 4 black circles would all be valid results.
One issue for the general case is that there are 4 possible solutions for the circle between two arcs and one line. In the image if you used the 2 blue circle and the blue line as your input, the 4 black circles would all be valid results.
Yes, that's why using an approximate geometry sketch (before dimensions and constraints) gives it the desired direction and indicates the expected solution.
Kacper Suchomski
basically was doing it right figured since they have option for three lines they might be a different way
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
