circle tangent to two arcs and one line
rclement
rclement
i was wondering if you can draw a circle which would be tangent to two arcs and a line.i see it has circle tangent to 3 lines.
i accomplished it drawing the two arcs and line drew a arc and then used tangent constraints
just wondering if there was a command i dont know
kacper.suchomski
Hi
This is done standardly - draw an approximate circle and give it 3 constraints.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Scott_Parker
One issue for the general case is that there are 4 possible solutions for the circle between two arcs and one line.  In the image if you used the 2 blue circles and the blue line as your input, the 4 black circles would all be valid results.
Scott Parker
Principal Software Engineer
Scott_Parker
One issue for the general case is that there are 4 possible solutions for the circle between two arcs and one line.  In the image if you used the 2 blue circle and the blue line as your input, the 4 black circles would all be valid results.
Scott Parker
kacper.suchomski
Yes, that's why using an approximate geometry sketch (before dimensions and constraints) gives it the desired direction and indicates the expected solution.
Kacper Suchomski
rclement
basically was doing it right figured since they have option for three lines they might be a different way
Type a product name
