Circle dimension shown as a Radius rather than a Diameter
Hey,
Upon drawing a design upon an .idw file, I have stumbled upon this small problem, and not too sure how to solve off the top of my head.
What I have done is dimensioned a hole on the drawing, but shows it in the form of a Radius, rather than what I want, which is a diameter. I'm not too sure how I can change this; I have looked around on it but still puzzled. I wonder if I can acquire some quick help off you guys please.
The version of Inventor I am using is: Autodesk Inventor 2015.
I'm running this on Windows 10 on 64-bit (if any of this matters I don't know).
I've attached below what I am on about, where the circle is Dimensioned "R3", rather than (and what I want) 6.
Thanks,undefined
Replies (8)
JDMather
Select the dimension and the right click - you should see an option to set it to Diameter.
It looks like you have a hole intersecting a cylinder.  This is sometimes seen as a arc rather than a circle and therefore Inventor defaults to R rather than Ø but it is easy to fix.
Hey there,
I can't find that option at all when I right-click the dimension, unless I'm not seeing right. Attatched below are the options I have when Right-Clicking. I'm not sure which window to collect
P.S. You're undefinedright, it is a circle drawn onto the side of a cylinder, intersecting it. Just to let you know
hossaiy
here is a short  video which illustrates JD's instructions:
Yacoub Hossain
mcgyvr
The command is only available until you "ok" the dimension.. Then you are stuck.
You could also just use hole and thread note instead of regular dimension and it should give you your diameter right away.
JDMather
mcgyvr wrote:
You could also just use hole and thread note ....
...assuming you created the feature as a Hole feature rather than Extruded circle cut.
Thank you so much!! 😄
mcgyvr
hole/thread tool still works with extruded circular cuts..
JDMather
I'm getting lazy.  I should have checked that out.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
