Check in from Vault, with Inventor is closed.
guillermo.martinezC6FK8
Good Morning,
Is it possible do "Check in" from Vault, if Inventor is closed.
Thank you.
Frederick_Law
Yes, if files were in Vault already.
New files should be Check in from Inventor first.
Gabriel_Watson
Vault usually has a setting to prevent check-in of design content without using the related design tool (AutoCAD/Inventor/etc.).
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/You-must-add-desig....
You can always override/toggle it off, then get a warning that can be skipped. Please note that you may lose some relationships between files if you check in a file onto Vault by dragging and dropping from Windows File Explorer or via right-click check-in via Vault client.
Thank you Galaxybane for your help.
