Changing Transparency of Workplanes (Autodesk Inventor 2011)
In the new version of Inventor, the  workplanes seem to be somewhat transparent on one side, yet solid on the other side. Is there a way to change this so that both sides are reasonably transparent, or even better, to choose how transparent they are?
You can change the Translucency of work features using the Color Scheme Editor available in the SDK folder. Be sure to set the Editor to the correct version of Inventor. (Inventor 2012 = Version 16.0)
Sorry for this question, but where is the SDK folder?
blair
It should be located within the Autodesk Install directory: Autodesk>Inventor 2011>SDK
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Great, thanks. This fixed my problem!
