Hi All,
New here so unsure if this is the right place to post this, I've had a look and can't find this question being asked before.
Due to the current pandemic i'm currently working from home with my PC connected up to a single monitor rather than my 2 monitors at work. When i try to check in an assembly to the vault from inventor the pop up with the progress bar appears and completes, but the pop up where you confirm which parts you want to check in with the check boxes doesn't.
I think its appearing off screen as inventor stops responding and every time i click i can hear the ping telling me to click the active window. I've tried minimising the screen and looking behind inventor and it's not appearing there, its not appearing in the task manager or the taskbar so i can't switch to it either. any ideas on how to solve this will be greatly appreciated, i'm on a tight deadline and unable to save my work back to the vault.
Thanks in advance,
Charlie
