Hey,
I use Autodesk Inventor professional 2019 so I wonder if there is a way to be able to change the length of a product in 3d-model eg. by mabye pull it, instead of going into the sketch to do it.
For example, I want to change the length of a rod from 100-300 mm in 3d model. How i do that?
Best regards,
Muntadar Daebes
My email: muntadar.daebes@nfgab.se
Solved by mcgyvr. Go to Solution.
May I ask why you dont want to do it in the model?
@muntadar.daebes wrote:
Hey,
Best regards,
Muntadar Daebes
@muntadar.daebes See "Direct" button in the modify section of the 3d model tab.. That allows the functionality you want..
@muntadar.daebes is this an imported part from another software that has no editable features?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Hi! Yes, like experts mentioned here, you can use Direct Edit command to drag the faces to lengthen it. If you are a subscriber, you can download and install Feature Recognition tool from Autodesk Inventor App store (https://apps.autodesk.com/PDSU/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win32_64).
You can convert some geometry into parametrically driven features like Extrude, Revolve, and Sweep. Then you can change the parameters.
Many thanks!
