Inventor Forum
Changing the color of bending line in Flat Pattern
8 REPLIES 8
Message 1 of 9
1376 Views, 8 Replies
Hi everybody,
When we create Flat Pattern from sheet metal parts (Go to Fat Pattern), both Up and Down bending line are in yellow color. I am going to change the color of Up bending line to green and Down bending line to red in Flat Pattern.
thanks
8 REPLIES 8
Message 2 of 9
jhackney1972
You question sounds more like a statement.  I doubt that you succeeded in changing the color of the bend lines in the Model "Flat Pattern".  This can be accomplished in the drawing "Flat Pattern" and in an Export of the Flat Pattern but that is about it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 9
in reply to: jhackney1972
Hi
I am going to change the color of bend line in the model not in the drawing.
thanks
Message 4 of 9
IgorMir
Good luck!
@Anonymous wrote:
Hi
thanks
Web: www.meqc.com.au
Message 5 of 9
mgeurts
You can have different bend line colors in your dxf export:
Inventor Professional 2021
3DS Max 2022
Win 10
Message 6 of 9
IgorMir
in reply to: mgeurts
Yes, but the OP wants to do it on model level, not in Export to DXF DB.
Message 7 of 9
colombia693
how did you get there
Message 8 of 9
mgeurts
in reply to: colombia693
RMB on Flat Pattern and choose Save Copy As
After pressing Save you will get this window; under Layer you will find the options
If you want to keep your changes for other DXF-exports than Save Configuration
3DS Max 2022
Win 10
Message 9 of 9
brad
I love the idea of being able to add different colors to the bend lines in the model flat pattern so you can easily identify the different bends. right now all bend lines are the same color. It's hard to tell the bends apart on more complicated sheet metal parts. Can we add this thread to the idea station? Otherwise, I will post there.
