Hey all,
I'm editing a drawing template. In this template, I've created a rule that is not triggered by any events (I've checked) except for a button in a Form. When I'm in said Form, I've set it up so that there are several User Parameters that I can change, and when I hit "Go," it writes those parameters to various places. One of the parameters is a Multi-Value Parameter (MV_Para).
The problem is that when I change MV_Para, before I've had a chance to hit "Go," the iLogic Rule runs automatically, writing whatever happens to be in the boxes for the other User Parameters to their appropriate places. This problem only occurs for MV_Para, it does not occur when I change the other parameters. The Rule also runs as soon as I change MV_Para from the Parameters manager window.
I'd like to stop this Rule from auto-running and have the "Go" button be the only way (within the Form, of course) to run the Rule.
How can I accomplish this?
Thanks!
-Luke
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
I think you want this option selected under the ilogic interface
Mark Lancaster
& Autodesk Services MarketPlace Provider
