Changing Model States modifies View Representations
- Mute
- Permalink
- Report
I am having a problem with Model States and View Representations. I have an assembly with a component pattern of subassemblies. Those subassemblies have a "LESS HARDWARE" View Representation to turn the visibility off of common nuts, bolts, spacers, etc to conserve memory and declutter drawing views. When I go between two model states that change the parameters of the component pattern, elements that are added back when the parameters increase always default back to a "Master" View Representation.
I am not sure if this is the intended (or unintended) functionality, or I am missing a step in my work flow. To change the view representation of the sub assemblies, I select one of them inside the pattern elements, and choose "Select all Occurrences" then "Representation..." and change the design view in the dialogue box. This works as expected until I change away from and then back to the larger component pattern model states. I have tried making the view changes with single and all model state scopes selected, and tried making the view changes associative.
Any insight into this problem would be greatly appreciated.
-Thanks
Inventor Professional 2022 64-Bit Build 153, Release 2022.0.1
Dell Precision 7820 Tower w/ Windows 10 Pro 20H2
Inventor Professional 2023.0.1
Windows 11 Pro 21H2
