Inventor Forum
changing font size
8 REPLIES 8
Message 1 of 9
2184 Views, 8 Replies
changing font size
Hi
8 REPLIES 8
Message 2 of 9
Mark.Lancaster
@Anonymous
How are you entering the information?  Typing 2 mm?
If you are using metric units, why are you using an ANSI text style?
Have you defined the text height list in your standard?
Mark Lancaster
Message 3 of 9
in reply to: Mark.Lancaster
Thanx Mark.
Message 4 of 9
johnsonshiue
Hi! The screenshot shows you entered "2/00mm." Is that true? Did you try 2.00mm?
Many thanks!
Software Test Engineer
Message 5 of 9
in reply to: johnsonshiue
Thanks Johnson.
Yes I tried 2.00 mm but didn't work.
Message 6 of 9
SBix26
Please share a screen shot of 2.00 mm not working (or 2,00 mm).  Both of your screen shots show the '/' character instead of the decimal separator, which will certainly not work.  Also, you will need to select the text before changing the size, just as you would in Microsoft Word.
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
Message 7 of 9
in reply to: SBix26
HI Sam.
12.png13.pngI first entered 2.00 mm but after I clicked enter key Inventor showed the  error.and change the font size to default that in case is 3/50 mm.
Message 8 of 9
SBix26
Is your system decimal separator set to '/' ??  If so, I think this is a problem, because Inventor uses this character as the division operator in parameter fields.  Otherwise, I don't know how to interpret what you are showing in your screen shots.
Sam B
Windows 7 SP1
Message 9 of 9
in reply to: SBix26
Thanx alot Sam.
As you said I changed data type from our Persain calender to english and it solved.
