I am trying to apply dimensions to an assembly to be displayed in fractions. These are the steps that I went through:
All parts are in a isometric view and I am using Inventor Professional 2011
These are directions in the Help. What am I missing?
Solved by ravikmb5. Go to Solution.
Have u changed style in object defaults
In the styles editor menu tree on the left. Object defaults. Once you create a style you assign that style to whatever types of annotations you want it on. That way you can have (for example) one dimension style for all your linear dimensions, and a different one for radius dimensions... etc. Most people would not do that, but IV gives you that flexibility.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Assign the styles in the Object defaults
