Message 1 of 8
changing completely from inches to mm
Moin!
At first: I already know about setting the units via document settings. I also know about unit-settings via Application options and the templates, ....
I would like to totally convert complete assys incl. parts from inch to mm, AND I would like to get mm directly set inside the parameter lists. Attached you will find a pic after setting the doc-units to inch. The nominal value (grey background) is OK, but I need the Equation (white background) as well in mm.
After unit setting:
My dream:
There might be a problem concerning calculations or other references. First idea is to skip them.
Any ideas??
Hang loose!
Kay
Cheers
Kay (Principal CAD-Consultant)
