I am using a Parts List in an Inventor Drawing of an Inventor Assembly that contains parts with Base Unit 'Each' and Frame Generator members with Base Quantity 'm'. I set the Part Number in the BOM for all of the similar frame generator members to the same value so that they roll-up in the Structured BOM.
This works fine. The Parts List in the drawing displays the 'Each' components without a unit / decimal precision and the frame generator parts all get nicely summed up which is what I want. Unfortunately the decimal precision of the frame generator members is defaulting to 0.000 which is making my parts list untidy and I want to round this figure up to the nearest meter.
I have tried going into each frame member and changing the tolerance > precision on each and every member. This works to reduce the number of decimal places in the parts list once all of the members are changed but is incredibly tedious. It also doesn't quite fix my problem as I would like to round up and this approach rounds down.
I have also tried changing the column format of the parts list table or the QTY column to m and setting the decimal precision there using 'apply units formatting'. This works to fix the precision on the frame generator parts but unfortunately it also changes all of my normal 'each' parts too which is incorrect.
One thing that did look promising was introducing a substitution in the column format for the QTY column on the parts list table. I tried picking up the property 'G_L' which is a custom iProperty that the Frame Generator creates for all members that contains the length. My hope was to sum this field (which looks to be one of the options) and then be able to 'Apply Unit Formatting' of m with precision 0 for this sum. Unfortunately this doesn't seem to work as I expected and the parts list cell that it represents turns blue and has *Varies* in it. I've checked and all of the members have valid lengths in this G_L custom iProperty.
Any ideas as to how I do this? Any help gratefully received.
Hi, has the problem with BOM been fixed? I'm steel getting 3 decimals which is bad and no number of parts... Inventor 2021.4
Hi Andrey,
Like John mentioned earlier, it should have been fixed as of 2020.x update. Your issue may or may not be the same. Do you mind sharing an example here or start a new thread describing the behavior?
Many thanks!
Hi! Please share the files here. It could be a bug or a setting was not set correctly. Without seeing the files, it is impossible to tell.
Many thanks!
Hi John,
Good morning,
Thanks for your reply,
Enclosed herewith files for your review
Looking solution for SAP 090-00 x400mm Like this.
Hi! I see the issue now. You need to change "G_L" precision in the Description. The display precision for parameters is mainly controlled by Doc Setting. Open the frame member file -> go to Tools -> Doc Settings -> Units -> change Linear Dimension Displace Precision to 0. Then the "G_L" will be shown without decimal places.
Many thanks!
Hi! You could also change the Standard ipt template file so that its length unit display precision (Document Setting) is 0.
Many thanks!
Hi John,
I tried, but not getting the result,
can I know the file location?
I changed here,
Hi! I am very sorry that I had another episode of human multi-threading error. I was wrong. The display precision in frame member cannot be controlled by the Standard template files. It is controlled by the CC Family Template.
The workflows are a bit confusing I have to admit. There isn't one option to change to make precision behave desirably. Here is the workflow to change CC Family Template.
1) The "G_L" display precision was saved in the family template. For Standard Content, the family template cannot be changed. You will need to copy the structural family to a custom library. Then you can change the family template. The family template simply is an ipt file with desirable document settings.
2) After you make a copy of the family, you can place a structural shape member from the library into an assembly. Open the ipt file and go to Tools -> Doc Settings -> Units -> change length dimension display precision -> Save.
3) Edit CC Library, find the family, and change the family template by select the ipt file in step2.
This will help enforce "G_L" display precision.
Many thanks! Sorry for the confusion!
Hi John,
Thanks for your update.
All are clear, I am a little confused about this step.
3) Edit CC Library, find the family and change the family template by select the ipt file in step2.
Hi! You need to Copy the standard family and turn it into a custom family (with a link to the standard; link can be suppressed). Then you will be able to replace the family template.
Many thanks!
