Change part feature with Assembly constrain
milan5
milan5
Dear All,
I am trying to create assembly, in which I can link part feature with assembly constrain.
I have attached 2 images for reference. What I need is, if i change angle of nozzle than hole should also move.
Can anyone here guide me.
Milan Kantaria
Xun.Zhang
Hello @milan5,
Please leverage adaptive command to do so.
For example, In-place edit the cylinder part, find the hole feature, edit it and delete the original place point, try to project the circle from sub-assembly and make the circle center as the placement. Now the hole feature is set as adaptive automatically  and of cause, the part is adaptive as well.
Now try to change the angle, the hole is follow the pattern.
Hope it helps!
Xun
milan5
Dear Xun,
I have done something but it's not working. Please find attached assembly for reference.
Milan
Xun.Zhang
@milan,
Now it works!
Please remember that to click accept confiction and then press rebuild all to get the state up to date as video shows.
https://autode.sk/2JxJjXE
Hope it helps!
Xun
milan5
Now it works.....
Can you tell what changes you have made, because in my assembly adaptive symbol is not there and also in right click menu it shows grey out.
Milan
Xun.Zhang
Hi @milan5
Just removing unnecessary sketch and make the part adaptive, that's all.
Hope it helps!
Xun
