Change orientation of face appearances on different faces on part file
MikeKovacik4928
Advisor Advisor
Message 1 of 8
MikeKovacik4928
Inventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-010.jpgInventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-010.jpg
Hi Inventor Users around the world
See photo above
I am wanting to know if there is any way of lining up or orientating appearances
on different faces in a single ipt, or if I have to draw the wall as an assembly with separate bricks
in order to get the bricks correctly aligned and orientated.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (7)
Message 2 of 8
johnsonshiue
Hi Mike,
I believe the following page has the information you are looking for.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Many thanks!
Software Test Engineer
Message 3 of 8
MikeKovacik4928
Thanks Johnson
Whatever I do the manipulator icon doesn't appear
See jpeg below
Inventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-015.jpgInventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-015.jpg
Mike
Message 4 of 8
MikeKovacik4928
Johnson
By the way, I am trying this on Inventor 2017,
However I don't think that should make any difference,
the Inventor 2017 help is the same as the link you sent me.
Mike
Message 5 of 8
mcgyvr
@MikeKovacik4928 The manipulator icon is usually located centered on the face in which you are trying to manipulate..
Please post a screenshot showing your entire display..
Message 6 of 8
MikeKovacik4928
Never saw it!
It wasn't on the face but it was there.
Probably because the face had a cut out.
Inventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-016.jpgInventor Customisation Queries_004_Face Properties Change Face Appearance to Brick-016.jpg
Mike
Message 7 of 8
kelly.young
Autodesk Support
Autodesk Support
Hello @MikeKovacik4928 at timestamp 1:45 goes over Adjust:
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 8 of 8
MikeKovacik4928
Thanks Kelly
What a great video, it explains everything
Mike
