Hi Guys,
We have our system set up so that all our custom parts' description uses the member field. When I create a model state of any component it changes my part description to the model state which messes with the parts list. Our manufacturing team cuts raw material from the parts list and this is causing issues. Is there a way to change the default headers in the Excel sheet that the model state creates? If I can change it from Member to Model state it would help a lot. Is there an Excel sheet template somewhere in the C drive for this?
This is before the model state has been created:
![iUser_0-1629833800757.png iUser_0-1629833800757.png](https://forums.autodesk.com/t5/image/serverpage/image-id/956748iEA9397090A859482/image-dimensions/765x178?v=v2)
![iUser_1-1629833868548.png iUser_1-1629833868548.png](https://forums.autodesk.com/t5/image/serverpage/image-id/956750i77EA89120EF91BE0/image-dimensions/761x649?v=v2)
Then this happens when I create a model state in the part:
![iUser_2-1629833993900.png iUser_2-1629833993900.png](https://forums.autodesk.com/t5/image/serverpage/image-id/956752iD084393843104DC8/image-dimensions/761x175?v=v2)
Model state Excel sheet:
![iUser_3-1629834920784.png iUser_3-1629834920784.png](https://forums.autodesk.com/t5/image/serverpage/image-id/956758iF613CE4746A0D583/image-dimensions/759x187?v=v2)
How I would like to change the Model State Excel template:
![iUser_4-1629834973523.png iUser_4-1629834973523.png](https://forums.autodesk.com/t5/image/serverpage/image-id/956759i649DBEADF5B5DEE2/image-dimensions/759x167?v=v2)
Any help would be greatly appreciated!
PS. I tried manually doing it in this specific Excel sheet, but it gives an error, which is why I am thinking it needs to happen in the template file?
