Change layer between views in IDW
bbailey6E5PN
bbailey6E5PN
Hello, I am in the sheet metal environment a lot with my line of work. I have all my layers set up to transfer to AutoCAD for our laser to burn out. One problem is having my flat pattern and ISO view on the same layer. For example, my flat pattern is on our "PrimaryPart" layer and my ISO view showing the developed view is also on the "PrimaryPart" layer. I would like to change the ISO view to the "0" layer. Is this possible?
johnsonshiue
Hi! I don't believe so. All view edges regardless of views are on the default Visible Layer. Such designation is controlled by Objects Default on a per object type basis, not per view basis.
Many thanks!
Software Test Engineer
