Hi
Check Style & Standard Editor.
Kacper Suchomski
In Mange Tab > Styles Editor. Expand the text node and find what you have:
This should be changed in the project settings.
Kacper Suchomski
And setup different size:
Note Text small
Note Text mid
Note Text big
or
Note Text 1mm
Note Text 2mm
Note Text 4mm
Have you closed all files?
Kacper Suchomski
You can't modify the Project you're using.
Double click on "Default" to switch then click and edit.
You need to check out your project file.
Ok, you are using Vault. Do you have permission to edit Project and Styles?
You need to check out the Project file and Design Data folder.
Did you save it back to the style library?
Read my last post carefully. Save is greyed out so the change must have been applied.
No, that's not all. You saved the style locally, and you need it globally (icon next to S&SE). That's what Brad mentioned.
Kacper Suchomski
Saving the dialog box is not saving BACK to the style library.
