Inventor Forum
Change Feature Direction with iLogic
6 REPLIES 6
josephcooley
2333 Views, 6 Replies
How do you change a features direction (extrusion) with ilogic?
2011 win 7 x64
6 REPLIES 6
in reply to: josephcooley
if you search the Autodesk Inventor Customization forum for ExtentDirection I think you'll find some examples.
I think you'll use kPositiveExtentDirection or kNegativeExtentDirection or kSymmetricExtentDirection
ExtentDirection
Input constant that indicates which side of the sketch plane to extrude toward. kPositiveExtentDirection defines the offset direction to be in the same direction as the normal of the sketch plane.
edit: my search didn't turn up much, but here's an example from the COM API Reference
found at: C:\Program Files\Autodesk\Inventor 2011\Help\admapi_15_0.chm (I think on WinXP at least)
    ' Create a base extrusion 1cm thick.
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
                        oProfile, 0.25, kNegativeExtentDirection, kJoinOperation)
MjDeck
Here's a rule to do it.  It will work on an extrusion with Distance extents.
In this sample, Extrusion1_direction is a numeric parameter.  The function only cares about the sign (positive or negative) of this parameter.
Sub Main
 ChangeExtrusionDirection("Extrusion1", Extrusion1_direction)
End Sub
Sub ChangeExtrusionDirection(featureName As String, direction As Double)
  app = ThisApplication
  Dim extrude As ExtrudeFeature = TryCast(Feature.InventorFeature(featureName), ExtrudeFeature)
  If (extrude Is Nothing) Then Return
  If (extrude.ExtentType <> PartFeatureExtentEnum.kDistanceExtent) Then Return
  Dim extent As DistanceExtent = TryCast(extrude.Extent, DistanceExtent)
  If (extent.Direction = PartFeatureExtentDirectionEnum.kPositiveExtentDirection And direction < 0) Then
     extent.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
  ElseIf (extent.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection And direction > 0) Then
  End If
End Sub
Mike Deck
Software Developer
Autodesk, Inc.
josephcooley
in reply to: MjDeck
Hi @MjDeck I've got follow up question.  This is for a sheet metal face if that matters.
How can I make my ilogic code do the following psudocode
Value will be a multivalue text pull down in the ilogic form
If Value=A
Then Extrude one way
IF Value = B
Then Extrude other way
EndIf
MjDeck
@josephcooley , unfortunately the API function to flip the direction on a face feature doesn't work at this time. We have a work item named INVGEN-9652 for this.
Mike Deck
Software Developer
Autodesk, Inc.
JBerns
@MjDeck,
What is the status of this "flip direction" request for sheet metal features?
I am working on sheet metal flanges, contour flanges, and cuts, and have discovered several limitations related to feature editing.
For example, see this post:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/control-sheet-metal-cut-direction/m-...
I look forward to your reply.
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
MjDeck
in reply to: JBerns
Hi Jerry - it looks like it has not been implemented yet. I'm trying to find out what the plans are.
Mike Deck
Software Developer
Autodesk, Inc.
Technology Administrators
