like the subject explains, is it possible that you can change the description of the design features. Like when I place a bolted connection, the description in the BOM will be in english, can this description be changed in dutch?
Tony
Solved by cbenner. Go to Solution.
Since these are library parts pulled from your Content Center, you can modify the descriptions by editing the family table in the Content Center Editor. Sometimes it takes a little searching to find which column populates the Description property on the part. Once you find it, however, you can change it to whatever you want.
Parts that have already been used in your assemblies can then be updated by using the Refresh command.
In Inventor go to Modify, Editor, then find the family and right click. Select Family Table. Look for the column that seems to be your description, check it's mapping to the Inventor Property. if it is description, this is the field to edit.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
