Why the hole chart has commas instead of decimal points I don't know but does anyone know how to change them? Even my VAR can't figure this out.
Solved by blair. Go to Solution.
This might be related to number formating within the Windows O/S for country. Check: Start>Control Panel>Region and Language>Formats>Additional settings>Numbers>Decimal Symbol:
This also where IV picks its date format.
If it works, through a shrimp on the barbi for me
RBM on the Hole Table, to bring up the Edit Hole Table, at the bottom in the Column Settings, RMB on the XDIM and select Format Column. Over on the Units, in the Decimal Marker dialogue box, select .Period from the pull down menu. I suspect that yours is set to ,Comma.
That's the trick blair. Thanks too you and to all who assisted. That's been bugging me for 2 years! Thought I better get it sorted once and for all before we upgrade to 2013 next week!
Thanks blair. Your solution from 2013 still helping me on 2020. I just come across your prudent comment while seeking to eliminate the comma in Hole Table.
