I am trying to put a chamfer on the shoulder area of 2 equally sized cylinders meeting at right angles, effectively a Tee join.
I recently upgraded to Inventor 2018.
Prior to the upgrade the chamfer operation was no problem, producing a "cheese wedge" type shape.
However, since the upgrade it doesn't work.
Is there a setting I can change to make it work?
Hi Pieter,
Same here. But Fillet works as expected.
Cheers,
Igor.
Hi Pieter
Which Inventor version you can create the chamfer successfully? I checked on Inventor 2017 and 2018, both can't create chamfer.
Sucy
It's an interesting question @Anonymous.
Below is a result from Inventor 2017. The chamfer feature is highlighted. Could you confirm if this is what you're asking?
Hi Pieter,
I check the issue on Inventor 2016 again, the chamfer can be created successfully. So it seems a regression issue since Inventor 2017. Thank you for reporting the issue to us. I will log a defect and ask development team to resolve it.
Sucy
Hi Inchul Lee,
The result I am trying to achieve is as per attached, which was done in version 2014.
I can't recreate it in version 2018.
As Sucy mentioned - it looks like a defect.
