Inventor Forum
Chafmer
4 REPLIES 4
ayman.ghwini
325 Views, 4 Replies
Chafmer
I have another problem with chamfer. So I will enclose a few figures that show my work and the target one. Basically i have to chamfer the edges but it seems different to the target model and i can't get what i want.
Thanks a lot in advance.
Ayman
4 REPLIES 4
chenj
in reply to: ayman.ghwini
Do you want the following results?
ayman.ghwini
in reply to: chenj
thanks a lot for your answer. I have tried this but it seems a little bit different to the model shown in previous figure.
ayman.ghwini
in reply to: chenj
thanks a lot for your answer. I have tried this but it seems a little bit different to the model shown in the figure below.
johnsonshiue
Hi! Another approach is to use Ruled Surface. You can create a Ruled Surface by selecting the edges and specifying the angle relative to the side faces. After that, use Split or Sculpt to remove the unwanted portion.
Many thanks!
Software Test Engineer
