Certain hatch patterns not being printed
Message 1 of 59
After upgrading to 2016, certain hatch patterns are not being printed. Look at following example
In Inventor:
PDF file:
It looks like certain hatch patterns are not getting printed regardless of line weight, colour, etc.
Anyone had similar issue?! Smiley Frustrated
Replies (58)
Message 2 of 59
If you post the file, I will test here.
You might try increasing the vector resolution in the PDF export options.
Message 3 of 59
Cadmanto
Are you printing to pdf or saving to pdf?  Which ever one you are doing try the opposite.  Also, try a different pdf creator like Dopdf or Cute pdf Writer
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 59
blair
Or change the Quality from Standard to High-Quality in the PDF options
Delta Tau Chi ΔΤΧ
Message 5 of 59
There is nothing special about the file John.
Run Inventor 2016, create a new drawing file containing Gravel pattern. Then try to export it as PDF. If the result is good on your machine, then please let me know.
Same drawing file was OK  Inventor 2015 (before upgrading)
Message 6 of 59
Both actually.
The problem is explicit even in Print Preview stage. I doubt it to be because of PDF engine.
EDIT:
I tried other PDF creation engines (as suggested) but still no good. 😞
Message 7 of 59
I put it even to maximum detail level but still negative.
It sounds like a bug in v2016 to me. Don't you think so?
Message 8 of 59
blair
Since the Product Design Suite 2016 has shipped yet I am unable to test. I didn't have any issues with the Beta version (but a lot can change from Beta to final release). Generally changing the Quality from Standard to High Quality Print solves most issues in either the Export File as: PDF solves the problem. I'm using the latest version of Adobe Acrobat DC on my system.
Delta Tau Chi ΔΤΧ
Message 9 of 59
Blair, thanks for the reply.
As stated earlier, I doubt the issue is caused by PDF creation process because it exposes itself even in Print Preview stage.
These are outcome of PDF setting with different resolution as you suggested:
Normal:
High Quality:
As a workaround, I was hoping to open the drawing on my other machine which still has Inventor 2015 installed. Sadly, since I have once saved this drawign in 2016, it can no longer be opened in earlier versions complaining about imcompatibilty between databases. Any idea how I can revert it back to previous version at least to be able to open it in 2015 and send the drawing to client?!
Message 10 of 59
blair
Odd in deed, the only way to convert a 2016 file to 2015 is to export the IPT or IAM file to a neutral format such is STEP or IGES, import into 2015 and create a new IDW.
I have asked that this be forwarded on to Support to look at.
Delta Tau Chi ΔΤΧ
Message 11 of 59
Thanks for the effourt.
UPDATE
It turned out that only ANSI patterns, out of following list, appear in Print Preview (hence PDF):
Any other pattern except ANSI ones will be simply ignored.
Message 12 of 59
johnsonshiue
Hi! This is indeed wrong. I am able to reproduce it using PDF OUT and DWF OUT. I will follow up with development and see where the exact problem is and how to resolve it soon.
Many thanks!
Software Test Engineer
Message 13 of 59
Thanks Johnson. Well that would be highly appreciated if you investigate the issue and advise accordingly.
Meanwhile I ended up converting IDW files to DWG and make my PDFs out of AutoCAD instead.
Message 14 of 59
I have also come across this problem. I found it when trying to plot a drawing and no hatching shows up. I did test exporting and printing to Adobe PDF and have the same issue. This needs to be addressed soon as we use custom hatch patterns in a lot of our drawings that need to be present in prints.
Message 15 of 59
lando7189
It appears that Update 1 (5/5/2016) resolved this for exporting to PDF, but custom hatches still don't show up printing to a printer.  - Lanny
Message 16 of 59
I have also verified this, they export to PDF but will not print... don't even show up in the print preview.
Message 17 of 59
crystaltech
Hello All,
We are also seeing this issue.  Has anyone seen a resolution?
Thanks in advance.
Message 18 of 59
lando7189
Message 19 of 59
lando7189
I spoke too soon -- update 1 made it work for PDFs... but update 2 still doesn't send to a printer correctly.
- Lanny
Message 20 of 59
Paul-Mason
It been a while form my posting the original problem and there's still no resolution from Autodesk MAY BE in the NEXT hot fix but I'm not going to hold my breath.
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
