Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
Centre Line
9 REPLIES 9
Message 1 of 10
2370 Views, 9 Replies
Centre Line
You can see centre line with more gaps in the finished drawing. But it is not in my drawing. How to get it?
9 REPLIES 9
Message 2 of 10
Hi fiatnm,
I opened your drawing and was able to produce a line with dashes by re-applying the centerline and stretching it to fit. I do not know what your original problem was. You can get a solid looking line like that from stretching out one of the center mark tendrils. I hope this helps.
Edit: Not sure about the center mark being solid. They have always been solid for me, even in circular patterns like that. I fiddled with it a bit. Sorry, not sure how you are supposed to get dashes there.
2016-04-25 15_59_16-Autodesk Inventor Professional 2015 - [Otiose End Plate with Sigma Clip.idw].png
Message 3 of 10
mdavis22569
You can do as @Anonymous said ... however if you move the view the centerline doesn't move or change
If you do it as I show in the video when you move the video it will change
Mike Davis
Message 4 of 10
in reply to: mdavis22569
You can notice this centre line also dash line. How to make it dash line?
Message 5 of 10
mdavis22569
I don't know ... at least a quick way that I would want my guys to do it.   There is probably a work around but...is it work all the effort for something that isn't that critical and more of aesthetics
It could be a setting they had .... it could be because it was done in an older version and it was possible ...
Mike Davis
Message 6 of 10
JDMather
@mdavis22569 wrote:
...   There is probably a work around but.......
In my opinion the original is not done correctly.
Message 7 of 10
You want to right click on the centerline and click on add dashes. There's another tweak in that same context menu that evens the distribution of dashes out. There is a lot of goodies buried in the RMB!
-Mike
Tags (1)
Message 8 of 10
After your advice, I reopened the particular file, what a surprise I saw solid line turned into line with dashes. I don’t know how it happened.
Message 9 of 10
JDMather
in reply to: JDMather
To me this looks more aesthetically pleasing.
Message 10 of 10
Are you able to find out the reason from expertise?
