Inventor Forum
Centerline Sore Spot
4 REPLIES 4
149 Views, 4 Replies
I have drawings that are in 1:12 scale, and when I add some sketched
centerlines, phantom lines, or whatever, the dashes and dots are so small
that when I print it they look like continuous lines. Is there a way to
make the scale of the lines increase, and if so can it be done
automatically? I use LTSCALE for this sort of thing in AutoCAD.
4 REPLIES 4
Have a look at the Standards dialog General tab. There is a scale field on
the right; you might try changing that.
~Larry
"mpower" wrote in message
news:3E0EBAF6FB3264351B48B095578EE2AB@in.WebX.maYIadrTaRb...
Thanks, I just tried it and that does make the size of the dashes longer so
they are visible, but... my centermarks are now way to big. They went from
about 1" to 12" and look funny marking a 3/8 hole. Any other ideas?
"Larry Caldwell" wrote in message
news:E313C4DE1527302821E9F7FBF69ED132@in.WebX.maYIadrTaRb...
> ~Larry
small
Use 2 different dim styles
Cory McConnell
BJ pipeline Inspection
news:396E930206C838B092A158845E7D2724@in.WebX.maYIadrTaRb...
so
from
on
> > ~Larry
> small
to
You can set cL size in the Standards as well so I would imagine they could
be reduced by the same amount you increased the scale.
~Larry
so
from
on
> > ~Larry
> small
to
