Inventor Forum
Center of gravity as work point
6 REPLIES 6
3578 Views, 6 Replies
Dear all,
I have a question:
Is it possible assign a work point at the center of gravity?
Thanks in advance.
6 REPLIES 6
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Dear Dennis,
Thank you for the answere but the macro iCOG seems not work in my system. Infact the iCOG macro is not load by Inventor. I think that the problem is the windows vista 64 bit operating system. Could you solve thi problem?
I'm building up my XP64 system this weekend. I'll let you
know....
Expert
Expert.
AIP 2008 SP3,
.8185
Yijiang.Cai
View -> Center of Gravity to get the coordinate of COG and then assign a work point using the values of this coordinate. But the work point can't be associated with the changes of COG. Please see the attached image.
When you use the VBA code for assigning work point in COG below, it will be associative with the COG changed.
River
Public Sub WorkPointAtMassCenter()
' Check to make sure a part document is active.
If ThisApplication.ActiveDocumentType kPartDocumentObject Then
MsgBox "A part document must be active."
Exit Sub
End If
' Set a reference to the active document.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
' Get the Center of Mass.
Dim oCenterOfMass As Point
Set oCenterOfMass = oDoc.ComponentDefinition.MassProperties.CenterOfMass
' Check to see if a work point for center of mass already exists.
' This uses the name of the work feature to identify it.
On Error Resume Next
Dim oWorkPoint As WorkPoint
Set oWorkPoint = oDoc.ComponentDefinition.WorkPoints.Item("Center Of Mass")
If Err.Number = 0 Then
Dim oFixedDef As FixedWorkPointDef
Set oFixedDef = oWorkPoint.Definition
oFixedDef.Point = oCenterOfMass
oDoc.Update
Else
' Create a new workpoint at the location of the center of mass.
Set oWorkPoint = oDoc.ComponentDefinition.WorkPoints.AddFixed(oCenterOfMass)
' Rename the work point.
oWorkPoint.Name = "Center Of Mass"
End If
End Sub
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
Thanks.
Now I'm going to try your code and then I'll let you know if I manage to make it work.
Ok, the code works perfectly. I just added the condition <> in the first function "if":
If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then
bye bye
Edited by: nekao on Mar 24, 2009 5:19 PM
Edited by: nekao on Mar 25, 2009 1:46 PM Edited by: nekao on Mar 25, 2009 1:46 PM
