Message 1 of 10
Hey. Let's say I have an extruded rectangle. Now I add new sketch on one of its faces and sketch a point. This point will be used as a location for a hole, for example. I want this point to be centered on the face even if the rectangle's dimensions are changed. Or, I want this point to be at the middle of one of its edges (Image attached, showing that I want the point to always be in same distance from left and from right).
If this is a simple case, I would like to complicate it with a case which I want to sketch this point of one of a metal sheet flange (image attached).
Thank you very much!
