Cant use Inventor Cam 2020 in Inventor 2021
griptechshop
Message 1 of 15
griptechshop
How do you use Inventor Cam with Inventor 2021?
I have uninstalled Inventor 2020 and then installed Inventor 2021 but Inventor Cam 2020 cant work with Inventor 2021
tried to install the latest update for Inventor Cam (2020.31) but says that Inventor 2020 is missing.
What to do??????
Replies (14)
Message 2 of 15
mdavis22569
Hi @griptechshop
Unfortunately no.     Also Inventor Cam 2021 hasn't been released yet. It's usually mid-April when the collections are released not when the main individual software's are released.
Shouldn't be much longer
Mike
Mike Davis
Message 3 of 15
DarrenP
i assume you need to keep Inventor 2020 installed to be able use CAM 2020 with Inventor 2021
it works fine here but i still have Inventor 2020 installed
using CAM 2020.3 with Inventor 2021 see screenshot below
DarrenP
Message 4 of 15
mdavis22569
To add ...
I have to verify that I had 3.1 update for Inventor Cam installed for it to show up in my 2021....
However I'm not saying it's going to be fully compatible or work properly, that's something maybe @johnsonshiue could verify.
Mike Davis
Message 5 of 15
DarrenP
looks like you need to install Inventor CAM 2020.3.1 to be compatible with 2021
Compatibility with Inventor 2021
  • Fixed a licensing issue which prevented the 2020.3 update of Inventor CAM from running with Inventor 2021. (#19874)
DarrenP
Message 6 of 15
griptechshop
Hi Darren,
I guess my mistake was to uninstall Inventor 2020 first.
Have you still got Inventor 2020 installed on your computer?
Message 7 of 15
DarrenP
yes i do
you will need to install 2020 again if you want to use Inventor CAM with 2021 or wait until the 2021 version comes out
DarrenP
Message 8 of 15
griptechshop
Thanks for that.
Cheers,
Trevor
Message 9 of 15
DarrenP
Inventor CAM 2021 came out today
DarrenP
Message 10 of 15
griptechshop
Hi Darren,
Iv'e downloaded Inventor Cam ultimate 2021 and Inventor 2021, but it seems only Inventor Cam express has downloaded.
Cheers,
Message 11 of 15
johnsonshiue
Hi! Do you have an active subscription to Product Design and Manufacturing Collection?
Many thanks!
Software Test Engineer
Message 12 of 15
griptechshop
Yes I do,
I have found a solution thanks.
Message 13 of 15
johnsonshiue
Hi! Do you mind elaborating the solution? It will benefit other users.
Many thanks!
Message 14 of 15
griptechshop
You have to go to registry key and change the value of ProductEdition and type INHSMP
This worked for me.
Cheers
Message 15 of 15
info8WT72
Thanks for this!!!!!! I had the same problem, how does Autodesk not know this?
