Cant open files in Inventor 2020
Message 1 of 19
few days ago all of my Inventor Folders got deleted from the computer but I managed to restore them. But now Inventor is not allowing me to open them.
I managed to open few Models because I sent them to someone so I only had to download them again and tehy work. But the ones that got restored wont open. I keep getting the "Resolve Link" dialog box. (pictures are attached, but in german)
any Idea how to fix it ?
I did try copying the files in the mentioned path with no sucess.
Replies (18)
Message 2 of 19
SharkDesign
Are you using the right project file?
The files need to be in your project search paths for it to find them.
  Inventor Certified Professional
Message 3 of 19
JDMather
Zip and Attach the folder here.
Rather than open the assembly *.iam file - open each individual part *.ipt file.
Do they open OK?
If yes, then go back and open the *.iam file.
Each time it asks to Resolve Link - click on the appropriate*.ipt file.
What has happened is in addition to the file name that you assign, Inventor also assigns an internal file name.  Somehow in your process of restoration - Inventor sees these as different internal file names than what we’re originally referenced by the assembly.
Message 4 of 19
no, the .ipt wont open aswell
Message 5 of 19
SharkDesign
In the open dialogue, check that the file you are opening matches the year of your software.
Message 6 of 19
it does. I only worked with Inventor 2020 and have only 2020 installed
Message 7 of 19
SharkDesign
You were talking about some other people giving you files so wanted to make
sure they weren't on a different version.
Message 8 of 19
JDMather
Attach at least one of the *.ipt files here.
This should be easy.
Message 9 of 19
Gabriel_Watson
Your pictures show the errors opening an assembly. What error do you get when trying to open the IPTs/parts?
Did your Inventor get reinstalled, or your Windows user get renamed? Check if Inventor is still set as the default opener for the IPT files, by right-clicking an IPT and selecting "Open With":
C:\Program Files\Autodesk\Inventor 2020\Bin\Inventor.exe
If your IPTs no longer open even if you drag and drop them into an Inventor application, I would suggest a repair, then a reinstall if needed.
Message 10 of 19
JDMather
I recommend that you do not reinstall Inventor until you have Attached a file here.
I think the solution is much easier than reinstalling Inventor.
Message 11 of 19
it wont let me attach something over 71 MB
Message 12 of 19
rihab.maaaloul
Message 13 of 19
SharkDesign
That file is knackered mate. Don't think it got recovered properly.
Message 14 of 19
Gabriel_Watson
"Database" errors as such usually mean the file is corrupted and you can't do anything about it. Even Navisworks could not read it.
Message 15 of 19
rihab.maaaloul
ohh .. okay! I had the feeling it was corrupted so I started doing everything from scratch anyway...
thank youuu everyone
Message 16 of 19
JDMather
What is in your OldVersions folder?
Message 17 of 19
rihab.maaaloul
same problem
Message 18 of 19
johnsonshiue
Hi! The file is probably encrypted. I tried to open it using 7zip or Notepad. Neither can open the file. I am not sure it is a legitimate Inventor file, though it has ipt as file extension.
Many thanks!
Software Test Engineer
Message 19 of 19
SharkDesign
Johnson may have a point. I opened it in notepad and there was code there,
but it was as if it was all white text on white background and you couldn't
read any of it.
