cant create flat pattern
mgarcesUX9HW
Message 1 of 31
mgarcesUX9HW
Hi im new to inventor I know theres still a lot to learn pls help i cant unfold the attached file, please help what im missign thanks! this 3d model was created in autocad 2020 and exported to inventor 2020.
Accepted solutions (3)
Replies (30)
Message 21 of 31
mgarcesUX9HW
omg i just got this channel flatten with .000380 culprit, this is great got this one solve and probably will apply on next plate thank you for this troubleshooting on my channel
but still having problem on the pipe model wont able to rip but JDMather said its a bad model
Message 22 of 31
mgarcesUX9HW
hi JDMather how can i run a quality check on inventor so that I could any model from autocad?
Message 23 of 31
johnsonshiue
Hi! I thought I already provided the answer (Thicken -> Intersect). The body quality is fine. It is just that the bend zone thickness is inconsistent. Please take a look at the part.
Many thanks!
Software Test Engineer
Message 24 of 31
mgarcesUX9HW
thank you guys for all the infos,
I have another diagonal member i want to rip and create  cut template, i cant rip this of, please advise whats wrong with this model so I will know next time how to create correctly see attached
Message 25 of 31
johnsonshiue
Hi! I am not sure I understand this dwg file. There seems to be a structure. What are you trying to do in Sheet Metal? Please share your attempt here. Forum experts can help take a look.
Many thanks!
Message 26 of 31
mgarcesUX9HW
hi sorry for not so clear, yes its a diagonal member of a space frame column both ends are 6 od vert pipe, im trying to rip it so i could create a cut template for cutting the ends of this pipe
Message 27 of 31
mgarcesUX9HW
Message 28 of 31
JDMather
@mgarcesUX9HW
Why did you attach a dwg rather than a *.ipt file?
See Attached.
Message 29 of 31
mgarcesUX9HW
this is awesome JD thank you!, I attached a dwg so that I will know if my 3d autocad will work for inventor, because im loosing my mind in figuring out what hell im missing why i cant rip this off even a simple pipe it so hard for me, i did thickening, change the metal thickness etc, can you please tell me the steps you made, to make this work im new to this, and im frustrated, thanks!
Message 30 of 31
JDMather
@mgarcesUX9HW wrote:
...can you please tell me the steps you made, to make this work im new to this, and im frustrated, thanks!
All of the steps are in the history.  No secrets.
If you run into trouble - Attach the file at point of trouble.
Message 31 of 31
mgarcesUX9HW
ok will do thanks!
