cant create flat pattern
mgarcesUX9HW
Message 1 of 31
mgarcesUX9HW
Hi im new to inventor I know theres still a lot to learn pls help i cant unfold the attached file, please help what im missign thanks! this 3d model was created in autocad 2020 and exported to inventor 2020.
Accepted solutions (3)
Replies (30)
Message 2 of 31
You're most likely going to want to recreate this in Inventor using the sheetmetal tools. This part does not have a uniform thickness so it will not be able to be flattened. I would recommend drawing the cross-section and using Contour Flange to create this part in Inventor
Message 3 of 31
JDMather
Outside Radius = Inside Radius +Thickness
or
Inside Radius = Outside Radius - Thickness
Message 4 of 31
mgarcesUX9HW
hi it supposed to be inside + thickness, maybe this was causing the error?
Message 5 of 31
mgarcesUX9HW
but what would be the minimum bend raduis of a 0.5" thick mild steel?
Message 6 of 31
mgarcesUX9HW
for this matter any autocad model will not work with inventor for flat pattern, i have a pipe also that wont rip same modelled in autocad
Message 7 of 31
SBix26
An AutoCAD model should be able to be flattened in Inventor, but only if it is modeled correctly (absolutely uniform thickness throughout the model) and if the Inventor sheet metal defaults are set to the same thickness.  Also, of course, that all bends are conical or cylindrical-- formed by press brake or roll.
Please attach an example or two of AutoCAD models that you want to flatten.  Someone can demonstrate for you, if you tell us what version of Inventor you're using.
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
Message 8 of 31
johnsonshiue
Hi! To create Flat Pattern in Inventor, the body thickness needs to be uniformed. In this part, the thickness is not consistent in the bend zone. The quick workaround is to use Thicken/Intersect to create the uniform thickness. Here is what you need to do.
1) Go to 3D Model tab.
2) Click on Thicken command -> uncheck Auto-Blending and check Auto Face Chain -> select the outside face and set the distance to Thickness -> set the operation to Intersect.
Or, it needs to work from inside out.
The resultant body should have uniform thickness.
Many thanks!
Software Test Engineer
Message 9 of 31
mgarcesUX9HW
Hi I have tried this but it gives me an error
Message 10 of 31
mgarcesUX9HW
Hi thanks! attached are the modelled in autocad
1. socketpl2.dwg = cant seem to flattened it
2. column frame = i need to create a cut template for the pipe but it wont even rip
thank you please advise
Message 11 of 31
mgarcesUX9HW
im using
autocad version 2020
inventor 2020
Message 12 of 31
SBix26
Here's your answer (forums won't allow me to paste or embed images today 😠).
Inventor doesn't do "close enough" math.  It needs to be exact to a lot of decimal places.  I moved the two offending faces to exactly 1/2" using Direct Edit, and the channel flattens just fine.
Sam B
LinkedIn
Message 13 of 31
JDMather
The original AutoCAD geometry was not modeled correctly.
This image is of the edges of two "concentric" fillets in AutoCAD.
Those two horizontal lines should be overtop of each other.
I am zoomed wayyyyyyyy in...
Message 14 of 31
mgarcesUX9HW
1. did you recreate it in inventor using 2s sketch or just modify from the model itself?
2. so i have to be .00000 accurate on my model? to be able flatten it
Message 15 of 31
JDMather
please advise
Some of this geometry does not pass Inventor quality check.
Based on what we have seen so far - I would not trust any work from this AutoCAD user.
I would use the dwg only as reference in creating high quality geometry in Inventor from scratch.
(There is no reason that it couldn't be created in AutoCAD - but it is more difficult to figure out what the AutoCAD user is doing wrong and even to recognize their errors.)
On the other hand - with a complete parametric history - it is easy to diagnose issues and then avoid them going forward.
Message 16 of 31
JDMather
There is no reason you can't have .000000000000000 accuracy in AutoCAD.
Message 17 of 31
mgarcesUX9HW
how can i check the parametric history from autocad model, i think this model was created from basic autocad extrude and solid to solid  subtract command
Message 18 of 31
SBix26
I did not recreate the channel in Inventor, I just moved the two inside faces and their adjacent fillets .00038 inches toward the outside using the Direct Edit tool.
Sam B
LinkedIn
Message 19 of 31
JDMather
how can i check the parametric history from autocad model...
Did the AutoCAD user use Parameters?
Did the AutoCAD user set DELOBJ = 0 ?
Message 20 of 31
mgarcesUX9HW
unfortunately delobj was set to 3
