Inventor Forum
Cannot use fillet after creating solid via sweep tool.
12 REPLIES 12
Message 1 of 13
j.lanoszka
1160 Views, 12 Replies
Is there any way to use a fillet or some other tool to create a round edge on solid that was made by sweep tool ?
I think sweep tool is the only tool that provides me exactly what I want so I am not considering other tools for creating my solid part.
Every tip is appreciated. Thanks.
Labels (3)
12 REPLIES 12
Message 2 of 13
JDMather
in reply to: j.lanoszka
I do not see a Sweep feature in the part that you attached.
Did you attach the correct file?
If this is the correct file and you meant to write Loft rather than Sweep -
what size Fillet to you want?
On bottom edge only?
Message 3 of 13
JDMather
Maybe something like this?
Message 4 of 13
j.lanoszka
in reply to: JDMather
Yes exactly. I meant loft of course not sweep. My mistake, sorry.
Yes, I want it on bottom surface, just as you did it.
Could you please explain how to do it, cause I receive error like this below:
Message 5 of 13
JDMather
Did you look at my file?
Your sketch was very rough and not fully defined.
I started over from scratch.
Message 6 of 13
johnsonshiue
Hi! I think this part can be done without using Loft. I guess this is a modeling sequencing issue. The rounds (fillets) should be added after the shape has been defined. Adding detail geometry too early can lead to unnecessary complexity.
Please take a look at attached part. I remove the rounds. Then simply extrude it with a taper angle. After that, you can add the fillets to those edges. The geometry should be much easier, precise, and clean to work with.
Many thanks!
Software Test Engineer
Message 7 of 13
j.lanoszka
in reply to: johnsonshiue
Thank you Johnson for your advice.
I've got one more question about this part. Next step I need to do is cutting a specific shape on the curved face of the part. See picture in attachment. The cut needs to look like sketch_10 and 2mm thick into the part.
I think I've tried everything but achieved no success at all. I'm only able to cut this part just like I upload it here with the use of sweep tool, but I do not have any idea how to get the profile like on sketch_10.
Message 8 of 13
SharkDesign
Why are you using sweep to cut this?
Start a sketch on the sloped side, project the sketch onto that and then cut it.
I'm assuming you want that entire inside area cutting into it?
  Expert Elite
  Inventor Certified Professional
Message 9 of 13
j.lanoszka
in reply to: SharkDesign
Can you do it on attached file and upload it ? Then I tell you if it is what I want.
Message 10 of 13
JDMather
Create a 2mm offset surface body.
Extrude-Cut to the surface body and then hide the surface body.
See Attached.
Message 11 of 13
johnsonshiue
Hi! This can be done in multiple ways. You can also project the 2D wire to the face (in 3D Sketch). Then use Split command -> select the 3D curve to split the face. Lastly, use Thicken -> Cut to create the dent.
Many thanks!
Message 12 of 13
j.lanoszka
This part drives me crazy.. Now I am not able to create a shell after using sweep tool. Anyone wants to support again ?
Many thanks.
Message 13 of 13
johnsonshiue
Hi! Shelling should be done before detail features (fillets and chamfers) are added. For your part, right after Extrusion 8 is a good place to create the shell. I am able to shell up to 4 mm.
Many thanks!
