- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem that I have been trying for days to get around.
I am building a model airplane fuselage (to be 3D printed) and I have created a body using loft and then shell. I have also added a few internal features inside the hollowed out body.
Now I want to use a surface to split the body into two parts, the fuselage and a canopy. However, I get the error message:
"Create parting line failed Flygplanskropp sliced150424-1.ipt: Errors occurred during update Split1: Could not build this Split Split feature could not create two bodies. Change the Split Tool so that split feature can create two bodies"
It does not seem to matter which surface I use, I have tried with different work planes.
Having tried a number of different things I have seen that if I suppress the "shell" command then the split will work, but this will not help me...
I am stumped, I really cannot figure out what I am doing wrong and I have not found any other posts with a solution.
Thanks for any help!
