Cannot open file "...templates/standart.ipt"
sthh11
Message 1 of 9
sthh11
When starting Inventor 2019 I got the message "Cannot open file C:\User.....\Standard.ipt and if I try to open an existing file I get the following message "The file AdMaterialUI.dll can't be loaded..."
Can anyone help me with this issue?
I have already re-install it several times and I get the same message every time.
kelly.young has embedded your images for clarity.
Replies (8)
Message 2 of 9
mcgyvr
Close Inventor..
Try unzipping (extracting) and then copying the attached file into your "C:\Program Files\Autodesk\Inventor 2019\Bin" folder
Then restart Inventor
Did that help?
Message 3 of 9
johnsonshiue
Hi! I suspect this may have something to do with missing or incomplete install of Autodesk Material and Appearance Library. Please go to Control Panel -> Programs and Features -> find the following three programs in the same release as your Inventor.
-Autodesk Material Library Low Resolution Image Library
-Autodesk Material Library Base Resolution Image Library
They need to be there. Or, Inventor may not work correctly.
Many thanks!
Software Test Engineer
Message 4 of 9
sthh11
Hi. I have all of these. Thanks anyway /Stefan
Message 5 of 9
sthh11
Hi, I'm still not able to open the template. Thanks /Stefan
Message 6 of 9
MSD_takaseh
Hello sthh11,
My customer has same experience as this. His computer was infected by virus and a lot of dlls seemed to be corrupted.
It seemed to need to remove virus and recover the computer at that time.
Hitoshi Takase
Message 7 of 9
mcgyvr
Are you still getting the dll error after performing the steps I suggested?
My dll file is most certainly not corrupted..
Message 8 of 9
sthh11
Still a problem, Iwill replace my computer 🙂 /Stefan
Message 9 of 9
johnsonshiue
Hi! Two more things to try. Go to Get Started -> Projects -> look at the Material Library and Appearance Library. Are they highlighted in red? If yes, it means they are not set up properly. You need to find the library files and point the project to those files.
Go to Tools -> Application Options -> Files -> Configure Default Templates. Select the correct unit and standard ->Ok. You will get a new set of template files in your default Templates folder.
Many thanks!
