Cannot locate Draw tab and Equation Curve Command.
I am hoping to learn how to plot functions in Inventor 2015.
Therefore, I am trying to create an equation curve. When I look at
directions to do this, they all say to "Start the Equation Curve
command" within the Draw tab. I do not have that tab and therefore
can not find that command. Where is it located? THANKS IN ADVANCE!
swalton
The draw tab is shown in the sketch environment in a part or assembly file.
See http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8BF2EEB8-3A64-43F1-BA75-5ECBE357F08C
Steve Walton
Inventor 2025
Vault Professional 2025
When I click to create a sketch, I do not have a Draw Tab, I have a Create Tab. Inventor Capture.JPG
swalton
I don't have a copy of 2015 to check, but have you tried the dropdown arrow under the "Line" command or the one under the "Create" tab?
Steve Walton
Inventor 2025
It's under "Line" drop-down
Wow..of course I thought I had checked under all the drop downs. Thank you for helping!
TheCADWhisperer
Keep in mind that you are in a 2D sketch.
Of course if  you want a 3D equation curve then start a 3D sketch.
