Cannot install Inventor pro 2015
I cant install Inventor pro 2015. I have a free school licence but it doesnt work. I think it is a Hardware Problem. Look at the protocol in the attachment. i didnt understand that. Please help me...
mcgyvr
Did you use the "install now" method?
If so don't... Just download the individual files from the Autodesk Virtual Agent or use the "browser download" method to do the same..
TONS of people have problems with the install now method.. enough so that Autodesk should just remove it IMO..
mdavis22569
HI
So here is the issue:
Administrator R315P16 Rollback .NET Framework Runtime 4.5 SP1 Language Pack Failed Failure is ignored, Result=1619
Look at the following AKN
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Note: If you are installing on Windows 10, after the installation is complete, make sure that Microsoft .NET Framework 4.6 is installed.
  1. Open Programs and Features and click "Turn Windows features on or off."
  2. Make sure the entry for .NET Framework 4.6 Advanced Services is selected or partially selected with a solid black box.
Download it from the Virtual Agent would be my suggestion too
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Mike Davis
Mark.Lancaster
@Anonymous
Welcome to the community..
Your issue is related to the method you're using to download/install your application.  Its failing on download.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
mdavis22569
Click on the  links for your OS   32 or 64 (2 for 64 bit)
Autodesk Inventor 2015
Mike Davis
