I am trying to put text on a part but I keep getting the text mirrored and upside down.
I am placing a sketch on a plane and placing a text box on the plane but the text is the wrong way around.
See attached picture.
Thanks!
Solved by admaiora. Go to Solution.
Solved by mdavis22569. Go to Solution.
Attach the file,
However I believe you might be seeing your sketch plane from the back side ..making it look mirror
Hi Johan,
have you tried this?
Admaiora
Thanks Michael for your reply
You are correct, I do see the sketch from the wrong way, is there any way to tell Inventor that I see my sketch from the other way around and what is vertical?
Attached a file.
Can you atatch the file?
You can do it in many "direction"
For the second question.
Admaiora
Maybe this is your case..
Admaiora
Asmaiora, thanks for your answers.
To answers your first post, isnt that just looking from another way, you are not really changing anything in the sketch?
2nd Q. I think you flipped the whole sketch and looked at it from the other side.
Look at my privious post, there is a file attached.
Thanks!
Ok Johan, i have seen it now.
Admaiora
