I can install Inventor 2019 with ease. However I have been trying to install 2020 and am constantly getting a 1603 error. I have tried most options suggested here but nothing works.
I installed AIDA and get the following error:
Autodesk® Inventor® 2020 Log file last modified: Wed Jan 15 10:19:16 2020 exe_path=%platform%\INV\inventor.msi exe64_path= exe_param= inventor2020install.log Error occurs on line 8767 of log file (approximately) Context of failure in Log file is as follows: Collapse Entire Error Context MSI (s) (70:00) [10:17:08:699]: Doing action: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B Action ended 10:17:08: ProcessComponents. Return value 1. MSI (s) (70:F4) [10:17:08:704]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF94C.tmp, Entrypoint: licIsSvcUpgraded Action start 10:17:08: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Action start 10:17:08: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. 1: 5 2: Successfull registered 3: 0 1: 5 2: licIsSvcUpgraded 3: 0 1: 5 2: run helper with params: 3: 0 1: 5 2: "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\9.2.2.2501\helper\AdskLicensingInstHelper.exe" upgrade isUpgraded 3: 0 1: 5 2: process return code: 3: 100 1: 5 2: failed to upgrade 3: 0 1: 5 2: 3: 0 CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox) MSI (s) (70:00) [10:17:41:016]: Note: 1: 2265 2: 3: -2147287035 MSI (s) (70:00) [10:17:41:016]: Machine policy value 'DisableRollback' is 0 Action ended 10:17:40: licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B. Return value 3.
I have removed everything of Autodesk from the disk and registry but nothing helps...
I have no Idea how to resolve this?????
Anyone
Solved by nico.verduinVSE45. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! The error seems to indicate licensing service error. Please try updating the licensing service.
Then retry installing Inventor 2020. Are you sure all files were uninstalled? If not sure, you could use Microsoft FixIt to remove the prior installed Autodesk products.
Many thanks!
John
Thanks for the direction. The steps I took were:
a) use the uninstall program from autodesk and uninstall everything
b) delete in the folder C:\ProgramData the folder autodesk (takes some effort)
c) delete in the folder C:\Program Files (the complete autodesk folder)
d) delete in the folder C:\Program Files (X86) (the complete autodesk folder
e) delete the folder C:\autodesk (if it exists; seems to contain the web downloaded installations)
f) delete any autodesk folders in C:\Users\<Username>\AppData\local
g) delete any autodesk folders in C:\Users\<Username>\AppData\roaming
f) check with FixIt if there was anything left of autodesk
h) rebooted the system
i) install the downloaded Inventor Pro 2020 package.
and........
It works😀
Thanks again
Nico
