Cannot Flat Pattern Tapering Cylinder
mickmac06
mickmac06
I'm having problems creating a flat pattern from a tapering cylinder. The Cylinder has a cut down the length of it and it should be a simple operation to flat pattern it, but for some reason it isn't working. Any help would be much appreciated. Part attached below
-niels-
If you create your tapered cylinder with sheet metal functions it has better results.
I've attached a lofted flange version of your file, did not make it that accurate so make sure to check if it meets your requirements.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mickmac06
Thanks Niels,
I don't usually use the sheet metal tools, so I'll bear that in mind next time I need to do something like this.
Mike
JDMather
@mickmac06
One problem with the technique that you used is the cut edge is not perpendicular the to the thickness...
If you revolved a single (angled) line around an axis as a Surface Body and then Thickened - it would convert correctly to a Sheet Metal part.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
