Cannot emboss specific font - self-intersecting loop found
SEC_MECH
Message 1 of 11
SEC_MECH
I need to use a font specified by others - Quicksand.
When I extrude or emboss text written in this font I get an error - "Self-Intersecting loop found in this profile."
I can extrude and emboss other fonts. I need to use this font. How can I fix this?
Accepted solutions (3)
Replies (10)
Message 2 of 11
I think I would go to AutoCAD and use the express tools to explode the font into polylines.
I don't know why Inventor can extrude some fonts and not others.
Message 3 of 11
-niels-
Just to show you what the problem is, here's what you get if you change the font to text outlines in adobe illustrator:
I've circled the overlaps, there are more in other letters as well.
So, if you really have to use this font...
If you have access/experience with Illustrator (or maybe Inkscape, which is free) then you could change the font to outlines, clean it up and export it as dxf/dwg, import it in Inventor and see if it works then.
That's a way i can think of to use this specific font, though it is a lot of work if you need to make changes...
Hope it helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 11
johnsonshiue
Hi! I am not sure what happened. It seems to work for me. Please take a look at attached part.
Many thanks!
Software Test Engineer
Message 5 of 11
-niels-
@johnsonshiue i think you found yourself another bug!
Im not sure why but the font that got embossed is not Quicksand, see what happens when i highlight the sketch over the emboss:
Seems to me the embossed font is the previously used Arial, because if you suppress that first emboss the 2nd one fails.
Niels van der Veer
The Netherlands
Message 6 of 11
johnsonshiue
Hi Niels,
Good catch! I was not paying enough attention to the difference. This is a bug for sure. We do have font-specific profile issue. Besides converting to geometry using another tool, I cannot think of a different way. I will work with the project team to understand it better. But, I don't anticipate a quick fix here.
Many thanks!
Message 7 of 11
SEC_MECH
Thanks Niels. I think that you are right.
I have tried downloading this same font from different sources to see if there is any difference.
I discovered that there are two variants with the same name and author.
The official Google font has even sized loops to the "8" character.
This constantly fails regardless of where I download it from. https://fonts.google.com/specimen/Quicksand?preview.text_type=custom&preview.text=8
https://fontswan.com/quicksand-font/
The other variant has small and large loops used in the 8. https://www.dafont.com/quicksand.font?text=8
This variant extrudes successfully but does not match the graphics produced externally that I need to match.
Message 8 of 11
SEC_MECH
Strange. I don't see that.
Yep - Had more than my fair share of Inventor bugs!
Message 9 of 11
SEC_MECH
Thanks Yannick. That might work but would be a lot of work to maintain.
Message 10 of 11
SEC_MECH
I found a version of the font that extrudes/embosses.
Thanks all for your ideas and support
Message 11 of 11
-niels-
Yes, this is a nice "clean" version of that font. Good find!
Just to show, there are no overlaps in this one when converted to outlines in Illustrator:
Niels van der Veer
The Netherlands
