@kebby77 wrote:
our workgroup sharesa 3d folder and we are unable to edit or change each others models and drawings using inventor. any suggestions? a possible file option checked? please help
http://forums.autodesk.com/t5/inventor-general-discussion/file-sharing-editing-of-3d-documents-and-d...
You do NOT need to create another post as you already have one for this same problem. Creating another post won't help.
You NEED to provide information when requested. So far you haven't provided enough information to properly diagnose your problem.
You have file permissions issues..
You need to solve those permissions issues..
We cannot help you if you can't provide proper information..
How are you achieving a "vault" (as stated in your other post) ? Is that software you have purchased to create this functionality? If so what is the company and name of that software?
Or is it just a regular network location that you just save your files in?
Do you have an IT department that is familar with user permissions?
Can they join this discussion so they can clearly state the problem?
If you right click on any of the files through windows explorer you can go to the "security" tab and view the groups and users and their permissions to the files.
That is step #1 in diagnosing the issue.
More than likely your users need to be in a group that has permissions to modify and write to that file.
