Hi all
I am using a basis sketch in a part to control a couple of extrude features based on results from Excel and iLogic
I have been able to include the sketch in the drawing in a couple of places, one being as in the attached picture, showing in green (the result of excel and iLogic on the right...)
I am trying to dimension from the basis (green), I can select it, but I cannot dimension from it
You are far more likely to get a response if you post a samlpe data set.
If you cannot attach the actual files - make up simple dummy files that exhibit the same behavior.
Ok, I found the problem, and also the work around, but Autodesk might want to look into this because in my opinion, this should not be a problem...
I have a break in the view that I want to dimension. Normal dimensioning from the part itself works fine, and dimensioning from part planes also work fine, but not from the part sketch as I need to.
So in a way, tx JD, you helped me stumble onto the cause...
I was busy getting a pack-and-go set ready, deleting all the background stuff that is not needed so that I can post it here, and in the process I shortened my part and I thought let me just check if I can now dimension (Murphy has caught me many times like this...), and boom, I could dimension...
I have attached the files so you can have a look at it. I had to remove 003 due to size constraints but it should not affect what I am trying to point out
