- Mute
- Permalink
- Report
I tried searching for an answer and was unsuccessful.
I'm new to Vault and have not worked with it before. Our IT dept has installed the server end and I am able to check in/out etc. I am trying to add parts to the Content Center. I created a simple test part that has the required parameters and authoring done to it. I am able to publish this to our existing non Vaulted Content Center.
My issue is that I cannot create a category to publish the part to in the Vault Content Center. When I log in as Administrator, select the library, which is set to read/write, select the specific library in the view drop down, and right click the "Create category" option is grayed out. There are no other categories showing if that matters.
I have tried to make sense of the documentation, but this area is unclear to me.
Thank you.
