Inventor Forum
Can't use inventor 2015.
91 REPLIES 91
Message 1 of 92
kasnorma
14806 Views, 91 Replies
I freshly installed inventor 2015 and it start up to a blank white screen and unable to click on anything.
I have attempted repaire/reinstall and complete uninstall and reinstall.
System specs are as follows:
Dell percision M6800
OS: Windows 7 Pro 64 bit
CPU: Intel I7-4700MQ
RAM: 32GB Kingston HyperX
SSd: Msata 500GB Samsung EVO 840 (Autodesk products and windows installed here)
Hdd: 2 x 1 TB 7200rpm
GPU: Quadro K3100M (latest driver installed)
91 REPLIES 91
Message 2 of 92
JDMather
in reply to: kasnorma
Did you install with UAC and anti-virus temporarily disabled?
Message 3 of 92
mdavis22569
in reply to: JDMather
Did you try opening an existing file ? I don't know if this matters ...but what version of Microsoft Office are you using ..it requires a min of 2010 or higher (my work and another place I help are both on 2007 still)
Mike Davis
Message 4 of 92
raith-mb
Message 5 of 92
kasnorma
in reply to: raith-mb
so I can open an older inventor file I created but the start screen seems to just crash with inventor 2015 x64. And yes this was installed with UAC disabled and antivirus off that didn't seem to fix the issue either. also odd note if i start inventor first then open a file it will open the file but the mouse will be unable to click on anything and will have the pointer with circle noting it is busy thinking still.
Message 6 of 92
kasnorma
On furthur review i was able to fix the issue by unchecking "show my home at startup" in the general tab of options so this seems to be an issue with the my home.
Message 7 of 92
scottmoyse
Yeah... you likely won't miss the new Home anyway.
Scott Moyse
Product & Platform Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 8 of 92
kasnorma
in reply to: scottmoyse
Though I would like the option that exsist to work as this seems to be a bug.
Message 9 of 92
johnsonshiue
Hi! Did you send in the crash report? If yes, what email address was it filed under (send me an email: johnson.shiue@autodesk.com)?
Thanks!
Software Test Engineer
Message 10 of 92
ChrisMitchell01
kasnorma,
If/when you see that white screen, on startup, you can go to Task Manager & kill the 2 processes called AdCefWebBrowser.exe *32. After that Inventor should be Ok again for that session. To prevent this from recurring, go to Tools App Options, General tab & uncheck, "Show My Home on Startup", (as you've discovered).
If Inventor won't start at all, to even do this, you can run regedit & change ShowWelcomeScreen" to 0 under [HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion19.0\System\Preferences\File]
Which virus checking software & firewall are you using ? Does MyHome work properly if you temporarily disable those ?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 11 of 92
As the symptoms are similar, you might also check this "white screen" problem resolution:
http://www.cadforum.cz/cadforum_en/empty-white-activation-window-tip7739
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Message 12 of 92
My ShowWelcomeScreen was set to 0. I changed ShowHomeBaseOnStartup to 0 and got it working.
Regards.
Message 13 of 92
ChrisMitchell01
Thanks Paul,
Sorry about that - typo ! It should be ShowHomeBaseOnStartup that is set to 0.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 14 of 92
I just had this on a brand new install for a customers laptop. Fixed now... I assume this will be fixed in the next hotfix or something.
Scott Moyse
Message 15 of 92
Hi Scott,
We haven't identified the root cause for this issue yet. Can you supply any further info about the virus software that was in place on that machine ? Does the problem go away when disabling virus checker ? Any info in the virus logs to suggest what was being blocked ?
Anything in system event logs etc ?
Chris
Chris Mitchell
Autodesk, Inc.
Message 16 of 92
@ChrisMitchell01 wrote:
Hi Scott,
Chris
Sorry Chris, I didn't have time to do all this before the customer left.
Scott Moyse
Message 17 of 92
deniseking2654
I just downloaded and intalled the educational version of Inventor 2015 and I can't even create a new assembly without it crashing. I tried the regedit fixes and nothing is working. I can't even open existing files without an immediate crash.
Message 18 of 92
in reply to: ChrisMitchell01
Hi Chris
Sorry to hijack the thread, but we are also getting this startup issue with inventor 2015.
If 'show my home' is checked on startup we get the attached screen. If we uncheck Inventor starts and runs ok, except if you pick any of the 'My Home' buttons you get the Warning dialog again.
If I start Inventor 'run as admin' the home screnn shows OK if checked on. Also the buttons in 'My Home' work OK.
I believe it must be an IE / proxy setting somewhere, but cant track it. What is AdCefBrowser.exe actually doing when starting up inventor, what is it looking for or trying to access that when running 'as admin' is OK, but as a user it stalls Inventor.
I have just done a search on my laptop for adcef and found a journal file 'Report.wer' in c:\users\stephen.musitano\appdata\local\microsoft\windows\WER\reportArchive\AppCrash_AdCefWebBrowser._cc228aff321db7c8bf811b429961fd3e5c027_1ef9baec
Not sure if this helps in any way. I have changed the extension to TXT so as to upload
Hope this helps a bit more light.
Steve Musitano
Technical Manager
Datech UK part of the Tech Data Group
Message 19 of 92
ChrisMitchell01
Hi Steve,
We're still investigating this issue with another customer who has reported that same issue; based on the outcomes of those investigations we may contact you again for further info.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 20 of 92
Had the issue on customers machine and disabling Trend Micro antivirus allowed the window to appear. I guessing there is an exception we can add to trend micro.
