Inventor Forum
Can't subtract two solids
1 REPLY 1
jianchen.yu
228 Views, 1 Reply
jianchen.yu
I'm working on a bent threaded rod and I'm having some issues subtracting two solids.
Attached is the model file.
Thanks!
Thanks!
1 REPLY 1
johnsonshiue
in reply to: jianchen.yu
johnsonshiue
Hi! I guess the Sweep geometry has minor deviation. Try this. Make XY plane visible. Edit Sweep1 -> change it to Guided -> select XY plane as the guide. After that, the Boolean should work.
Many thanks!
Software Test Engineer
Many thanks!
