Can't simulate overhead crane structure
Hi!
It's the first time I'm having troubles simulating...
Most of the times I do a manual calculation and start adding reinforcement elements with the software and simulate in order to achieve the results I want...
This time It's not different, but I can't get the simulation done.
I get the "Degenerate element" (or elements) and the "The results were not obtained. To promp data updates, use the Rebuild All command, and then run Simulate again."
I have checked all the materials, used the simulate again.. moved loads, try with and witout some structures.. and I just can't get it done...
Any help in here? I'm trying to reinforce an existing structure in order to work with an overhead crane.
Thanks!
without roof or other elements, same warnings..
