can't see green mid point
Hi!
I can's see the green mid point.
The file is attached.
Here are my settings
mdavis22569
probably need to show more ..
however ..
have you gone thru the basic Tutorials provided in Inventor, or training with your local reseller?
Mike Davis
I am working with tutorials of @JDMather.
They are really good!
mdavis22569
Yes they are ...
But have you gone thru the basic's first..
Mike Davis
JDMather
Explain exactly what you are trying to do.
You must be in an active command for the snap points to appear.
For example, in the Line command or in the Sketch Point command.
Is the geometry you are trying to snap to in the current sketch?
If not, you will need to Project Geometry to get it into the sketch before you will be able to snap to it.
JDMather
I don't understand the logic of your 125mm dimension on the right?
