Can't save file, only save as
WIRMNS
Message 1 of 10
WIRMNS
When I created a new file (or with a existing file), I can save it normally. After I have worked in the file, I can not save file anymore. I just get a message to do a save as. My file are in read-only mode.
The files are saved on the network without using the Vault.
Why is Inventor doing this?
I work with Inventor 2022 and Windows 10 Pro.
Replies (9)
Message 2 of 10
JDMather
@WIRMNS
Sounds like a network issue, but let’s do a simple check first -
Q1. What version of 2022 (Update Number) are you running?
Message 3 of 10
WIRMNS
Build 153 / Release 2022
Message 4 of 10
mluterman
This happens to me when I or someone else on the network has the file opened somewhere/anywhere (even on a monitor with a minimized window you can't readily see). Alternatively, if it's driving you crazy, just save it with a new name and use that one instead. (But the file was always found to be open somewhere else-and no, windows will not allow you to do anything about it).
Message 5 of 10
JDMather
@WIRMNS
First thing I would do is install the latest update for your version of Inventor...
Since you are not using Vault - I would use Projects
The *.ipj file could be on your local drive or on the network drive (I would try both ways - depending on how other users at your company access files).
Message 6 of 10
WIRMNS
We have this problem for a few month. Before it worked fine.
We already use a project file. We have like 10 Inventor running.
Is it possible that the problem is that not everybody have the same update?
Message 7 of 10
johnsonshiue
Hi! The behavior does not make sense. This is likely related to the user's read/write privilege and whether or not Inventor is allowed to save. A few things to check.
1) Install all critical Windows updates and the latest graphics driver.
2) Clean up %temp%.
3) For the folder you try to save to, make sure you have the read/write privilege.
4) Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin."
5) Install Inventor 2022.5.1 update.
5) Is the drive partitioned as FAT or NTFS?
Many thanks!
Software Test Engineer
Message 8 of 10
WIRMNS
I did all the points and tried again. the problem is still there.
The drive is a NTFS partition.
Thx
Message 9 of 10
johnsonshiue
Hi! Are you using a PDM system to manage the files? Is the folder a library folder? Is it an OneDrive folder?
Many thanks!
Message 10 of 10
WIRMNS
Thanks for the reply. I think we found the problem.
It has to do with system permissions.
